查看: 676|回复: 0
时尚浪漫野马敞篷成功改装AIRBFT台湾正品32段阻尼软硬可调避震器
发表于 2020-7-8 14:58:55 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Fashionable and romantic Mustang convertible successfully refitted airbft Taiwan genuine 32 segment damping soft and hard adjustable shock absorber
1: Main functions: four wheel independent lifting, front and rear independent lifting and overall lowering; adjustable air tank pressure, working setting of air pump, three-stage memory,
Mobile phone app remote control, ignition automatic rise, automatic low prone, support Chinese, English and other languages, remote control panel with LCD display, main
To display the 4-wheel air bag pressure value and cylinder pressure value, more safely to feel the air shock culture for you to bring car fun.
