查看: 745|回复: 0
现代飞思改装AIRBFT气动避震低趴魅力
发表于 2020-7-7 17:16:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Modern freestyle modified airbft aerodynamic shock absorber low lying Charm
总是发“趴”在地上的车 好多人不理解 疑问也多,就通俗易懂的解释一下气动,通过改装四支“空气避震+控制器”从而达到在车内随意调节车身高度的目的,很多品牌高端配置车型也会有,它叫做“底盘升降” 差别在哪?升的没我们高,降的没我们低,升降速度没我们快。通常超跑 高端suv顶配才有的配置。
为什么越来越多人去改?
A lot of people don't understand and have a lot of questions about cars that are always lying on the ground. They can easily explain the aerodynamics. By refitting four "air shock absorbers + controllers" to achieve the purpose of adjusting the body height in the car at will. Many high-end configuration models of many brands also have them. What's the difference between them? The rising is not as high as ours, the descending is not as low as ours, and the ascending and descending speed is not as fast as ours. Usually, the top configuration of super high-end SUV is available.
Why are more and more people doing it?
