查看: 692|回复: 0
大众迈腾改装AIRBFT气动避震秀出低姿态
发表于 2020-7-7 16:57:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen maiteng refits airbft to show low profile
如果说低趴风格改装已成风,大家对此已经见怪不怪的话,那么相信接下来的这台本田奥德赛一定会非常引人眼球,继气动悬挂成为大家改装的主流之后,极端的“恐高症”患者们都开始往更加极端的方式去改装,低趴的姿态与硕大尺寸的轮毂完全不能满足他们的胃口,所以视觉效果十分夸张的宽体车身就成为了他们的改装方向。
If it is said that low lying style refitting has become a fashion, and everyone has seen it all the time, I believe that the next Honda Odyssey will be very eye-catching. After pneumatic suspension has become the mainstream of everyone's modification, the extreme "acrophobia" patients begin to modify in more extreme ways. The low lying posture and large size wheel hub can not meet their needs Appetite, so the visual effect is very exaggerated wide body body has become the direction of their refitting.
空气减震的优势
Advantages of air shock absorption
Air damping is to use pure gas as damping medium. It can make the four-wheel alignment parameters as much as possible to maintain the appropriate state when the vehicle is working, so that the ride is more comfortable. The vehicle can effectively reduce the impact when driving over the uneven road surface, and at the same time, it can provide sufficient lateral support force in the fierce handling. Effectively improve the handling. Make excellent driving performance and good comfort perfect combination. It can also effectively shorten the braking distance of the car. Save fuel consumption and reduce tire noise.
一般的胎噪主要由三部分组成:一是轮胎花纹间隙的空气流动和轮胎四周空气扰动构成的空气噪音;二是胎体和花纹部分震动引起的轮胎震动噪音;三是路面不平造成的路面噪音。空气减震可有效降低轮胎噪音: 空气减震有良好的阻尼的持续性和高速特性,阻力无空程,降低了轮胎和路面的阻力和摩擦力,降低了胎体和花纹部分的震动,即使是不平路面,轮胎的阻力减少,从而有效降低了胎噪。
The general tire noise mainly consists of three parts: the first is the air noise caused by the air flow in the tire tread gap and the air disturbance around the tire; the second is the tire vibration noise caused by the vibration of the carcass and tread pattern; the third is the road noise caused by the uneven road surface. Air damping can effectively reduce tire noise: air damping has good damping persistence and high-speed characteristics, resistance has no idle range, reduces the resistance and friction of tire and road surface, reduces the vibration of tire body and tread pattern, even on uneven road surface, the resistance of tire is reduced, thus effectively reducing tire noise.
