查看: 758|回复: 0
浪漫情怀奔驰威霆改装AIRBFT气动避震悬挂展现时尚低趴潮流
发表于 2020-7-7 16:30:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Romantic feeling Mercedes Benz Weiting refits airbft pneumatic shock suspension to show fashion and low lying trend
奔驰威霆承载着成熟办公空间的商务MPV,让您可以在车内享受到最人性化的功能体验。新V级是在高端商务车领域的全新作品。承袭梅赛德斯-奔驰家族设计语言,新V级造型大气简约而不失时尚,车内空间宽敞舒适,座椅布局灵动百变,充分满足各类商务出行需要,堪称中国商界精英最好的投资选择,将助力其奋斗之旅“出众亦从容。Benz V260 carries the business MPV of mature office space, so you can enjoy the most humanized function experience in the car. The new V-Class is a new product in the field of high-end business vehicles. Inheriting the design language of Mercedes Benz family, the new V-Class model is grand, simple and fashionable. The interior space is spacious and comfortable, and the seat layout is flexible and changeable. It can fully meet the needs of all kinds of business travel. It can be called the best investment choice of Chinese business elites, and will help them to make a journey of "outstanding and easy".
