查看: 688|回复: 0
优雅艳慕奔驰S560-W126级改装AIRBFT气动避震魅力演绎
发表于 2020-7-7 16:00:26 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
优雅艳慕奔驰S560-W126级改装AIRBFT气动避震魅力演绎Elegant yanmu Mercedes Benz s560-w126 modified airbft
全新奔驰S560-W126四驱版一直是这个级别的的霸主,基于 S 级打造的车型更是进一步的提升竞争力,特别是内部的用料做工和设计十分吸引。奔驰s560是大型豪华轿车的领军人物,大气、豪华、优雅均是亮点所在。实际表现完全可以满足任何商务行政场合需求。
The new Mercedes Benz s560 four-wheel drive has always been the overlord of this level. The model built based on the S-class will further enhance the competitiveness, especially the internal materials, workmanship and design are very attractive. Mercedes Benz s560 is the leader of large-scale luxury cars. Its atmosphere, luxury and elegance are the highlights. The actual performance can fully meet the needs of any business and administrative occasions.
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。通过过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。
Pneumatic shock absorber with elastic rubber airbag shock absorber, air pressure control system, air storage tank in rear compartment, electronic control system, etc.Through the air pressure to control the height of the car, is the so-called one low cover three ugly, the ultimate player's favorite is to be able to control the height of the car at will, very successful.
空气减震的优势
Advantages of air shock absorption
Air damping is to use pure gas as damping medium. It can make the four-wheel alignment parameters as much as possible to maintain the appropriate state when the vehicle is working, so that the ride is more comfortable. The vehicle can effectively reduce the impact when driving over the uneven road surface, and at the same time, it can provide sufficient lateral support force in the fierce handling. Effectively improve the handling. Make excellent driving performance and good comfort perfect combination. It can also effectively shorten the braking distance of the car. Save fuel consumption and reduce tire noise.
