查看: 677|回复: 0
成就人生主角奥迪A4B9改装AIRBFT气动避震案例
发表于 2020-7-7 15:31:23 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
The case of Audi a4b9 refitting airbft pneumatic shock absorber
关于改装气动避震的需求。正所谓一低遮百丑,改装绞牙避震也能降低车身,但是由于绞牙避震的依然是由避震筒和弹簧构成的,所以,在调节车身高低的时候,不能随心所欲的调节,而且绞牙避震能够调节高低的空间也有限。不少车友改完绞牙避震之后,会降车身降的很低,以达到提升操控性能,增强美观的作用。但是由于车身降的太低了,那么由于路况,减速带,地库等特殊环境,车子经常会磕碰底盘,心疼不已。所以,选择改装升级一套气动避震就是终极的姿态利器了。
The need for refitting pneumatic shock absorbers. As the so-called "one low cover a hundred ugliness", refitting the hinge shock absorber can also lower the car body. However, the hinge shock absorber is still composed of shock absorber tube and spring. Therefore, when adjusting the height of the car body, you can't adjust it as you like, and the space that the hinge can adjust the height is also limited. Many riders will lower the car body to a low level after changing the hinge suspension, so as to improve the handling performance and enhance the aesthetic effect. However, because the car body is too low, due to the road conditions, speed bumps, basement and other special environment, the car often bumps into the chassis, heartache. Therefore, choosing to upgrade a set of pneumatic shock absorbers is the ultimate attitude weapon.
So, what is pneumatic shock absorbers? The working principle of pneumatic shock absorbers is to change the height of the car by controlling the air pressure, so as to improve the trafficability of the car. It includes elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system, which will be more comfortable. At the auto show or the Party of car friends, we often see a lot of cars lying on the ground. Many people who have not seen it will think how the car can be so low! In recent years, car riders often talk about "one low cover three ugliness", and Hella flush is a modification style which deduces this sentence to the extreme. In hellaflush style refitted cars, in addition to paying great attention to the wheel hub J value, et value and exaggerated camper parameters, the remaining important problem is to reduce the body. So many friends will directly choose the hinge suspension, because it can not only reduce the height of the car body, but also provide sufficient support for the vehicle, which is welcomed by many riders with one stroke. However, for the ultimate players of Hella flush, the toothed shock absorbers have been unable to meet their "low" demand, so pneumatic shock absorbers have won the hearts of these ultimate players by virtue of its flexible ability.
Pneumatic shock absorber has always been regarded as an inevitable element in hellaflush modification. However, the modification of pneumatic shock absorber is not as simple as you think. It still needs owners to do some homework to choose pneumatic shock absorbers for their own cars. Different brands of cars are suitable for different levels of pneumatic shock absorbers, and the products of pneumatic shock absorbers are also different. In the face of their own cars and various brands, fans are holding their pocket money tightly and picking up pneumatic shock absorbers that will not let them regret. The pneumatic shock absorbers on the market are divided into two ways, one is mechanical pneumatic shock absorbers, the other is electronic pneumatic shock absorbers. The price of electronic pneumatic shock absorbers is generally higher than that of mechanical pneumatic shock absorbers, but the stability and reliability are not as good as mechanical pneumatic shock absorbers. After all, different brands and different models of pneumatic shock absorbers need car owners according to their own conditions But no matter what kind of pneumatic shock absorber, the most important thing after refitting is to know how to maintain it.
