查看: 751|回复: 0
雷克萨斯LS430安装AIRBFT气动避震精彩案例鉴赏
发表于 2020-7-6 17:42:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Appreciation of wonderful cases of installing airbft pneumatic shock absorber on Lexus ls430
一低遮百丑,百改降为先,改装不玩动力玩姿态,走姿态路线的玩家首选的就是气动避震悬挂,不走弯路,少花冤枉钱!
A low cover hundred ugliness, 100 change to the first, refit do not play power play posture, take the posture route of the player's first choice is pneumatic shock suspension, do not take detours, less money!
这几年HF改装火遍大街小巷气动减震,也是一夜变身改装界网红,话说这是个什么东西呢?它其实是一套可以控制气压,改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似,不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事,其中包括弹性橡胶气囊减震器,气压控制系统、后备箱储气罐及电子控制系统等,它其实和空气减震的原理与常见减震器螺旋弹簧+减震筒形式原理十分类似,只不过通过改变气室体积(上下方向),来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸,从而调节减震器的衰减力,因此空气减震器往往能提供更好的性能表现,嗯!就是这么自信!
In recent years, HF retrofit has been widely used in the streets and alleys for aerodynamic shock absorption, and it has also been transformed into a red screen overnight. What is this? In fact, it is a device that can control the air pressure and change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is such a set of things as shown in the figure below, including elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system. It is actually similar to the air pressure reduction system The principle of shock absorber is very similar to that of common shock absorber coil spring + shock absorber tube, except that by changing the volume of air chamber (up and down direction), the distance between the body and the ground can be adjusted and the soft and hard characteristics can be changed to a certain extent. In addition, the size of ventilation hole can be changed by the motor to adjust the attenuation force of the shock absorber. Therefore, the air shock absorber can often provide better performance table Now, um! So confident!
So, what is pneumatic shock absorbers? The working principle of pneumatic shock absorbers is to change the height of the car by controlling the air pressure, so as to improve the trafficability of the car. It includes elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system, which will be more comfortable. At the auto show or the Party of car friends, we often see a lot of cars lying on the ground. Many people who have not seen it will think how the car can be so low! In recent years, car riders often talk about "one low cover three ugliness", and Hella flush is a modification style which deduces this sentence to the extreme. In hellaflush style refitted cars, in addition to paying great attention to the wheel hub J value, et value and exaggerated camper parameters, the remaining important problem is to reduce the body. So many friends will directly choose the hinge suspension, because it can not only reduce the height of the car body, but also provide sufficient support for the vehicle, which is welcomed by many riders with one stroke. However, for the ultimate players of Hella flush, the toothed shock absorbers have been unable to meet their "low" demand, so pneumatic shock absorbers have won the hearts of these ultimate players by virtue of its flexible ability.
Pneumatic shock absorber has always been regarded as an inevitable element in hellaflush modification. However, the modification of pneumatic shock absorber is not as simple as you think. It still needs owners to do some homework to choose pneumatic shock absorbers for their own cars. Different brands of cars are suitable for different levels of pneumatic shock absorbers, and the products of pneumatic shock absorbers are also different. In the face of their own cars and various brands, fans are holding their pocket money tightly and picking up pneumatic shock absorbers that will not let them regret. The pneumatic shock absorbers on the market are divided into two ways, one is mechanical pneumatic shock absorbers, the other is electronic pneumatic shock absorbers. The price of electronic pneumatic shock absorbers is generally higher than that of mechanical pneumatic shock absorbers, but the stability and reliability are not as good as mechanical pneumatic shock absorbers. After all, different brands and different models of pneumatic shock absorbers need car owners according to their own conditions But no matter what kind of pneumatic shock absorber, the most important thing after refitting is to know how to maintain it.
