查看: 778|回复: 0
奔驰C级W205改装AIRBFT气动避震悬挂 低姿态打造活力时尚魅力
发表于 2020-7-6 17:25:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mercedes Benz C-class w205 refitted with airbft pneumatic suspension for low profile, dynamic and fashionable charm
空气减震的优势
Advantages of air shock absorption
Using pure air as damping medium. It can make the four-wheel alignment parameters as much as possible to maintain the appropriate state when the vehicle is working, so that the ride is more comfortable. The vehicle can effectively reduce the impact when driving over the uneven road surface, and at the same time, it can provide sufficient lateral support force in the fierce handling. Effectively improve the handling. Make excellent driving performance and good comfort perfect combination. It can also effectively shorten the braking distance of the car. Save fuel consumption and reduce tire noise.
