查看: 677|回复: 0
与您共享怀旧经典奥迪A8改装AIRBFT气动避震尽显奢华低趴魅力
发表于 2020-7-6 16:32:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Share with you the nostalgic classic Audi A8 refitted airbft pneumatic shock absorber to show luxurious low lying Charm
空气减震的优势
Advantages of air shock absorption
Using pure air as damping medium. It can make the four-wheel alignment parameters as much as possible to maintain the appropriate state when the vehicle is working, so that the ride is more comfortable. The vehicle can effectively reduce the impact when driving over the uneven road surface, and at the same time, it can provide sufficient lateral support force in the fierce handling. Effectively improve the handling. Make excellent driving performance and good comfort perfect combination. It can also effectively shorten the braking distance of the car. Save fuel consumption and reduce tire noise.
Taiwan airbft pneumatic shock absorber is specially customized for the actual needs of domestic pneumatic players!
1: Radical cure individual model (Cruz, Regal, yinglang, etc.)! )With the original car tower top model, equipped with bearing tower top! "Bearing tower top can solve the swing caused by the direction", so as to solve the problem of air leakage in the later stage.
2: Whether it's old cars or new models, the development of new models is timely and fast! All shock absorbers can not do the time effect! If you need to customize the extended shock absorber core for special models! The same security category within the first time to make the corresponding!
3: For the same model, what is the essential difference between SF's hinge suspension and pneumatic shock absorber! Lengthen the length of the shock absorber core and increase the lifting stroke. The shock absorber should deal with the special material treatment and material for the lowest point! The oil seal is also frequent piston movement! Use top NOK oil seal!
