查看: 5754|回复: 0
高尔夫MK7改装AIRBFT气动避震新款三段记忆版本施工细节
发表于 2020-7-5 17:21:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Construction details of golf Mk7 refitting airbft pneumatic shock absorber new three segment memory version
“避震方面,还是一步到位,直接选倍绞牙避震:四轮独立升降、前后独立升降、整体下降;气罐压力可调,打气泵工作设定,三段记忆,手机APP遥控,点火自动升高,熄火自动低趴,支持中,英文等多种语言,遥控面板自带液晶显示屏,主要显示4轮气包气压值和气瓶气压值,更加安全的去感受气动避震文化为您带来的用车乐趣。操控性比原厂大大提升了太多, 综合来说,AIRBFT避震器是一款耐用,调节方便,性能稳定的绞牙避震。”
"In terms of shock absorption, it is still in place in one step and directly select the double twisted teeth for shock absorption: independent lifting of four wheels, independent lifting of front and rear, and overall drop; adjustable pressure of air tank, working setting of air pump, three-stage memory, remote control of mobile phone app, automatic rise of ignition, automatic lowering of flameout, support of Chinese and English and other languages. The remote control panel is equipped with LCD display, which mainly displays the 4-wheel air bag pressure value and The air pressure value of the gas cylinder makes it safer to experience the fun of using cars brought by the pneumatic shock absorber culture. The controllability is greatly improved than that of the original factory. In a word, airbft shock absorber is a kind of durable, easy to adjust and stable performance of twisted teeth shock absorber. "
气动减震器的工作原理就是通过控制气压来改变车身高低,其包括绞牙减震器、气压控制系统和电子控制系统等。在车展或者车友聚会时,我们会经常看到很多“趴”在地上的车,很多没见过的人都会想这车怎么开啊,别担心,一键搞定你。安装气动减震器都会在车内链接一个控制遥控器,可以根据自己的要求来设定几个档位,可以实现多种高度之间的快速切换,这样就可以在停车时让车“趴”在地上,正常行驶时又能升到正常行驶的高度。
The working principle of pneumatic shock absorber is to change the height of the car by controlling the air pressure. It includes the toothed shock absorber, air pressure control system and electronic control system. At the auto show or the Party of car friends, we often see a lot of cars lying on the ground. Many people who have not seen it will think about how to drive this car. Don't worry. You can get it with one button. The installation of pneumatic shock absorber will link a control remote control in the car. You can set several gears according to your own requirements, and realize fast switching between various heights. In this way, the car can be "prone" on the ground when parking, and can rise to the normal driving height when driving normally.
