查看: 810|回复: 0
经典首选丰田皇冠安装AIRBFT气动避震,尽显低姿态气动姿态
发表于 2020-7-5 16:39:43 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
经典首选丰田皇冠安装AIRBFT气动避震,尽显低姿态气动姿态Toyota Crown is the classic choice to install airbft pneumatic shock absorbers, showing a low attitude aerodynamic attitude
“说实话,玩改装真的非常需要耐心,特别是玩姿态的,我相信大部分玩气动姿态的车主们,一定都体验过在路边抛锚,车子无法动弹的那种无奈,当时我真的有点气馁了,拖回改装店之后,一时的气急心烦,直接把车子还原不玩了,我想,这台皇冠的改装,就此告一段落吧。”
"To tell you the truth, it really takes patience to play with refitting, especially when playing with posture. I believe most of the owners who play with pneumatic posture must have experienced the helplessness of breaking down on the road and the car can't move. At that time, I was really a little discouraged. After dragging back to the refitting shop, I was worried for a moment, so I directly put the car back to play. I think the refitting of this crown is about this Come to an end. "
“直到有一天,我真正的接触到了VIP改装风格,了解到诸如丰田皇冠、CenturyMark II、LS400、以及日产公爵等等90年代初日系豪华车,这种素雅不夸张的改装风格,不正是当初我买皇冠的初衷吗?这让我回归初心,又燃起了热血,我要把我的皇冠打造成彻底的VIP风格!”
"Until one day, I really came into contact with the VIP refitting style. I learned about the Japanese luxury cars in the early 1990s, such as Toyota Crown, century Mark II, LS400, and Nissan Duke. This simple and elegant refitting style is not exactly the original intention of buying the crown. It makes me return to my original intention and ignite blood again. I want to make my crown into a complete VIP style!"
