查看: 735|回复: 0
永远的情怀大众高尔夫安装AIRBFT气动避震,搭配定制锻造五星轮毂,尽显气动姿态
发表于 2020-7-5 16:23:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
With airbft pneumatic shock absorber and custom forged five-star wheel hub, Volkswagen Golf shows its aerodynamic posture forever
说到老车,人们喜欢谈情怀。好比大众高尔夫,这辆车总是和情怀挂钩,尽管大众总是被人吐槽太过老旧以及质量堪忧等等,但还是会有人购买。情怀或许就有这种魔力,在情怀面前,人们会对一辆车念念不忘,这种车其实还包括大众高尔夫!
When it comes to old cars, people like to talk. Like golf, this car is always linked with feelings. Although the public is always too old and make complaints about quality, people will buy it. Feelings may have this kind of magic, in front of feelings, people will never forget a car, this kind of car actually also includes popular golf!
大众高尔夫,永远的情怀,来欣赏一下炫酷的改装版!我们眼前是一辆改装AIRBFT气动避震的大众高尔夫,这些减震器的改装充分体现出了高尔夫的超值魅力所在。有些改装显得运动感十足,而有些改装又显得是那么的华丽,不过归根到底,舍得改装高尔夫的人多多少少是因为被它的低趴魅力所吸引
Popular golf, eternal feelings, to enjoy the cool modified version! In front of us is a Volkswagen Golf which is refitted with airbft pneumatic shock absorber. The refitting of these shock absorbers fully reflects the super value charm of golf. Some of them are sporty, while others are gorgeous. But in the final analysis, most people willing to refit golf are attracted by its low lying charm
Taiwan airbft pneumatic shock absorber is specially customized for the actual needs of domestic pneumatic players!
1: Radical cure individual model (Cruz, Regal, yinglang, etc.)! )With the original car tower top model, equipped with bearing tower top! "Bearing tower top can solve the swing caused by the direction", so as to solve the problem of air leakage in the later stage.
2: Whether it's old cars or new models, the development of new models is timely and fast! All shock absorbers can not do the time effect! If you need to customize the extended shock absorber core for special models! The same security category within the first time to make the corresponding!
3: For the same model, what is the essential difference between SF's hinge suspension and pneumatic shock absorber! Lengthen the length of the shock absorber core and increase the lifting stroke. The shock absorber should deal with the special material treatment and material for the lowest point! The oil seal is also frequent piston movement! Use top NOK oil seal!
