查看: 870|回复: 0
气动避震李洋与您共享阿斯顿马丁改装AIRBFT气动避震发货包装案例
发表于 2020-7-5 15:30:36 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Pneumatic shock absorber Li Yang shares with you the case of Aston Martin modified airbft pneumatic shock absorber
有着智慧与美貌的阿斯顿马丁可谓是精彩的跑车标榜,算得上是中等级别的超级跑车,超级跑车喜欢它的无非就是减震的榜样,很多车友都想把它进一步的强化,空气减震是使用纯气体做阻尼介质,通过改装减震器,电脑遥控 ...等等等这些让它的更多潜力发挥出来,现在这款阿斯顿马丁经过改装 ,能使车辆在工作时使四轮定位参数尽可能的保持在恰当的状态,让乘坐着更舒适。车辆在驶过不平路面时能有效化解冲击的同时,又能在激烈操控时提供足够的侧支力。有效提高操控性。让优异的驾驶性与良好的舒适性完美结合。还能有效缩短汽车的制动距离。节省油耗,降低胎噪。让您感觉很炫,很年轻化的感觉,很人一种很绅士,很的低调的感觉。Aston Martin, with wisdom and beauty, can be described as a wonderful sports car. It can be regarded as a medium-sized super sports car. What a super sports car likes is nothing more than an example of shock absorption. Many riders want to further strengthen it. Air shock absorption uses pure gas as damping medium, which is modified by shock absorber and controlled by computer ... and so on, so that it can play out more potential. Now the Aston Martin has been modified to make the four-wheel alignment parameters as appropriate as possible when the vehicle is working, so that the ride is more comfortable. The vehicle can effectively reduce the impact when driving over the uneven road surface, and at the same time, it can provide sufficient lateral support force in the fierce handling. Effectively improve the handling. Make excellent driving performance and good comfort perfect combination. It can also effectively shorten the braking distance of the car. Save fuel consumption and reduce tire noise. Let you feel very dazzle, very young feeling, very human, a very gentleman, very low-key feeling.
