查看: 662|回复: 0
大红艳丽张扬Hondacivic为您展现AIRBFT气动避震低趴姿态魅力
发表于 2020-7-5 15:05:32 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Hongdacivic shows you the charm of airbft pneumatic shock absorber and low lying posture
江湖传言,马路上超过两台车默认判定改装过避震器。
不知从什么时候开始,改装AIRBFT避震器变成了车界泰日天的首要想法
上怼百万豪车,下怼紧凑小钢炮,更被冠予“减震界的冠军”的称号。
也不知从什么时候开始,只要是新出的车型都要想想怎么才能改装最合适,
诸如MG6,领克03,菲斯塔这些运动轿跑。
比完外观比安全,比完安全比质感,比质感饰比动力。
It is said that more than two cars on the road will be converted into shock absorbers by default.
I do not know from when to refit the airbft shock absorber has become the car industry TAIRI Tian's first idea
It is also awarded the title of "champion in shock absorption field" for connecting millions of luxury cars on the top and compact steel guns on the bottom.
I don't know when to start. As long as it's a new model, you have to think about how to refit it,
Such as MG6, link 03, festa, these sports car run.
It is safer than appearance, more secure than texture, and more powerful than texture.
改装并不是高富帅的专属玩物
改装是一种时尚,一种态度
血液中涌动着机油
如果你也是这样不甘平凡
作为同样喜欢改装车的你,不知道《速度与激情》系列给你有多大的影响。而对于WB来说,从速1到速8,还有速9的预告片,看了不少于20次。当然还有其他的,如《极品飞车》,《头文字D》,《湾岸MIDNIGHT》等等。因为每一次的重温,都会给WB带来动力,带来启发,生活色彩更丰富!
Oil was surging in the blood
If you are not so ordinary
As you also like refitting cars, I don't know how much influence the "speed and passion" series has on you. For WB, from speed 1 to speed 8, and speed 9 Trailer, I watched it no less than 20 times. Of course, there are others, such as "top flying car", "headword D", "Bay coast midnight" and so on. Because every time we revisit it, we will bring motivation and inspiration to WB and enrich our life!
低趴风潮被越来越多群众认识,走过路过的朋友都拿起了手机一顿拍照,不过,不少吃瓜群众嘴里依然有疑问:这些车子这么低趴,怎么开上路的呢?在此建议主办方:不妨制作大型海报,设置展示区域,科普Hellaflush文化和气动避震器工作原理,我想群众们会更加受益。
More and more people are aware of the trend of low lying down. All the friends passing by picked up their mobile phones to take pictures. However, many gourd eaters still have doubts: how can these cars go on the road when they are so low? I suggest that the organizers: make large posters, set up exhibition areas, popularize hellaflush culture and the working principle of pneumatic shock absorbers. I think the masses will benefit more.
说到HellaFlush改装,HellaFlush不分车型,不分高低贵贱。不论HellaFlush风格改装从何而来,它都离不开气动避震的支持。
When it comes to the modification of hellaflush, hellaflush is regardless of the model and the high or low. No matter where hellaflush style modification comes from, it can not do without the support of pneumatic shock absorber.
So, what is pneumatic shock absorbers? The working principle of pneumatic shock absorbers is to change the height of the car by controlling the air pressure, so as to improve the trafficability of the car. It includes elastic rubber airbag shock absorber, air pressure control system, trunk air storage tank and electronic control system, which will be more comfortable. At the auto show or the Party of car friends, we often see a lot of cars lying on the ground. Many people who have not seen it will think how the car can be so low! In recent years, car riders often talk about "one low cover three ugliness", and Hella flush is a modification style which deduces this sentence to the extreme. In hellaflush style refitted cars, in addition to paying great attention to the wheel hub J value, et value and exaggerated camper parameters, the remaining important problem is to reduce the body. So many friends will directly choose the hinge suspension, because it can not only reduce the height of the car body, but also provide sufficient support for the vehicle, which is welcomed by many riders with one stroke. However, for the ultimate players of Hella flush, the toothed shock absorbers have been unable to meet their "low" demand, so pneumatic shock absorbers have won the hearts of these ultimate players by virtue of its flexible ability.
