查看: 650|回复: 0
奥迪A4B8改装AIRBFT电脑气动避震HellaFlush风格低趴效果案例
发表于 2020-7-4 17:50:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Audi a4b8 refitting airbft computer pneumatic shock absorber Hella flush style low lying effect case
HellaFlush已经成为了一个国际化的改装车的外观潮流随着国内改装车的发展与进步,越来越多的被大众所接受,HF范儿也成为了一种品位的象征
Hellaflush has become an international appearance trend of refitted cars. With the development and progress of domestic refitted cars, more and more are accepted by the public. HF model has also become a symbol of taste
