查看: 783|回复: 0
奥迪R8成功改装一路豪横的AIRBFT气动避震器
发表于 2020-7-4 17:39:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Audi R8 successfully refits a bold airbft pneumatic shock absorber
它们不仅可以跑,而且跑的可以很精彩!
不然怎么能叫“贴地飞行”呢!
The low lying posture that can be seen everywhere in life also makes many laymen have doubts With the car so low, is it easy to run? Do you dare to run like this!
They can not only run, but also run very exciting!
说起低趴姿态,将汽车稳稳落地的功臣源于后备箱这小小的气罐。运用物理气压的原理将车身升高降低!来满足改装低趴的乐趣!
低趴改装风格已经成为一种时尚,贴地的车身让它比较倾向超跑,酷酷的外表很是抓人眼球,也许是因为它与众不同!
Speaking of the low prone posture, the contribution to the steady landing of the car stems from the small gas tank in the trunk. Use the principle of physical air pressure to raise and lower the body! To meet the fun of refitting low lying!
Low lying refit style has become a fashion, the body close to the ground makes it more inclined to run, cool appearance is very eye-catching, perhaps because it is different!
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
Pneumatic shock absorption
话说这是个什么东西呢?
它其实是一套可以控制气压改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似,不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事
其中包括弹性橡胶气囊减震器气压控制系统、后备箱储气罐及电子控制系统等,它其实和空气减震的原理与常见减震器螺旋弹簧+减震筒形式原理十分类似,只不过
通过改变气室体积(上下方向)来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸,从而调节减震器的衰减力,因此空气减震器往往能提供更好的性能表现,嗯!就是这么自信!
So what is this?
It is actually a device that can control the air pressure to change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is such a set of things as shown in the figure below
It includes the air pressure control system of the elastic rubber airbag shock absorber, the air storage tank of the trunk and the electronic control system. In fact, the principle of the air shock absorption is very similar to that of the common shock absorber coil spring + shock absorber, except that
By changing the volume of the air chamber (up and down) to adjust the distance between the body and the ground and change the soft and hard characteristics to a certain extent. In addition, the size of the air vent in the shock absorber can be changed by the motor to adjust the damping force of the shock absorber. Therefore, the air shock absorber can often provide better performance, eh! So confident!
