查看: 857|回复: 0
向您展现马自达阿特兹改装AIRBFT高度尺杆气动避震的现场细节
发表于 2020-7-4 15:40:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Show you the details of Mazda ATZ refitting airbft height bar pneumatic shock absorber
全新阿特兹,人马一体的高级驾感 :无论是起、行、转、停,无论是驾驶者还是乘坐者,都能感受到车辆的反应符合人预期,加速、减速、转弯线性、连续、平顺,没有延迟、顿挫和突兀,带来安心和舒适的驾乘体验。
New ATZ, a high-level driving feeling of human horse integration: whether starting, running, turning, stopping, whether it is the driver or the passenger, you can feel the response of the vehicle in line with people's expectations, accelerating, decelerating, turning linear, continuous and smooth, without delay, stumbling and abrupt, which brings a comfortable and comfortable driving experience.
为什么越来越多人去改?
改装玩家: 一低遮百丑 气动配合好轮毂的尺寸和数据可以把车降到最低。静止时,把车降到最低趴在地上,帅。行驶时,根据路况任意调节喜欢的高度。
不改装 日常代步车主: 你可以认为他是为了方便任意上下马路牙子。
很多女人说 好好的车干嘛要改 你也很美 干嘛要化妆
Why are more and more people doing it?
Refit player: one low cover hundred ugliness pneumatic matching wheel hub size and data can reduce the car to the minimum. When stationary, lower the car to the lowest, lying on the ground, handsome. When driving, adjust the height you like according to the road conditions.
Do not refit the daily car owner: you can think that he is to facilitate arbitrary up and down the road.
A lot of women say that a good car needs to be changed, and you are beautiful. Why make up
Taiwan airbft pneumatic shock absorber is specially customized for the actual needs of domestic pneumatic players!
1: Radical cure individual model (Cruz, Regal, yinglang, etc.)! )With the original car tower top model, equipped with bearing tower top! "Bearing tower top can solve the swing caused by the direction", so as to solve the problem of air leakage in the later stage.
2: Whether it's old cars or new models, the development of new models is timely and fast! All shock absorbers can not do the time effect! If you need to customize the extended shock absorber core for special models! The same security category within the first time to make the corresponding!
3: For the same model, what is the essential difference between SF's hinge suspension and pneumatic shock absorber! Lengthen the length of the shock absorber core and increase the lifting stroke. The shock absorber should deal with the special material treatment and material for the lowest point! The oil seal is also frequent piston movement! Use top NOK oil seal!
