查看: 766|回复: 0
AIRBFT气动避震李洋为您讲述坦途空气悬挂拉房车神器
发表于 2020-7-4 15:18:15 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft pneumatic shock absorber Li Yang tells you about the air suspension car God
坦途大皮卡,其大小可以和悍马不差上下。很适合长途旅行的代步工具,它受到一度追捧的原因在于它的多功能性--集合了SUV的越野性能、卡车的载货能力、以及轿车的舒适性。
Tanto big pickup truck, its size can be about the same as Hummer. It is very suitable for long-distance travel. The reason why it was popular for a long time was its multi-function, which combined the off-road performance of SUVs, the loading capacity of trucks, and the comfort of cars.
Taiwan airbft pneumatic shock absorber is specially customized for the actual needs of domestic pneumatic players!
1: Radical cure individual model (Cruz, Regal, yinglang, etc.)! )With the original car tower top model, equipped with bearing tower top! "Bearing tower top can solve the swing caused by the direction", so as to solve the problem of air leakage in the later stage.
2: Whether it's old cars or new models, the development of new models is timely and fast! All shock absorbers can not do the time effect! If you need to customize the extended shock absorber core for special models! The same security category within the first time to make the corresponding!
3: For the same model, what is the essential difference between SF's hinge suspension and pneumatic shock absorber! Lengthen the length of the shock absorber core and increase the lifting stroke. The shock absorber should deal with the special material treatment and material for the lowest point! The oil seal is also frequent piston movement! Use top NOK oil seal!
空气悬架系统是以空气弹簧为弹性元件,利用气体的可压缩性实现其弹性作用的,压缩气体的气压能够随载荷和道路条件变化而进行自动调节,不论满载还是空载,整车高度不会变化,可以大大提高乘坐的舒适性。空气弹簧悬架因其独特的性能和适应性,正在逐步打入传统的钢板和螺旋弹簧领域。
The air suspension system takes the air spring as the elastic element, and realizes its elastic function by using the compressibility of the gas. The air pressure of the compressed gas can be automatically adjusted with the change of the load and road conditions. No matter full load or no-load, the vehicle height will not change, which can greatly improve the riding comfort. Because of its unique performance and adaptability, air spring suspension is gradually entering the field of traditional steel plate and coil spring.
空气弹簧的运动性能特点是:
负载能力可调;
弹性系数随负载变化;
负载变化肘,固有频率几乎不变;
固有频率较低。
The movement characteristics of air spring are as follows:
The load capacity is adjustable;
The elastic coefficient varies with the load;
When the load changes, the natural frequency is almost unchanged;
The natural frequency is low.
这些特点决定了空气悬架具有以下优点:
(1)乘坐更舒适安全;
(2)改善车辆的行驶平顺性;
(3)延长轮胎和制动片的使用寿命;
(4)负载变化时车身高度不变;
(6)减少对道路的冲击,保护路面,降低高速公路的维修费用;
(7)延长车辆的使用寿命并增加折旧值。
These characteristics determine that air suspension has the following advantages:
(1) Ride more comfortable and safe;
(2) Improve the ride comfort of vehicles;
(3) Extended service life of tires and brake pads;
(4) When the load changes, the body height remains unchanged;
(5) Reduce the maintenance cost of electrical, air conditioning, exhaust system, axle, body and chassis;
(6) Reduce the impact on the road, protect the road surface and reduce the maintenance cost of expressway;
(7) Extend the service life of the vehicle and increase the depreciation value.
