查看: 851|回复: 0
保时捷分享展现打造AIRBFT气动避震引领低趴魅力姿态
发表于 2020-6-26 17:21:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Porsche share show to create airbft pneumatic shock absorber to lead low lying charming posture
在性能的追求上来说,每一代保时捷都是站在了时代的巅峰,而作为汽车中传奇品牌的保时捷,更是以此而自豪无比,所以每一代保时捷都能够被广大车迷所追捧!
In the pursuit of performance, every generation of Porsche stands at the peak of the times, and as a legendary brand in the car, Porsche is very proud of this, so every generation of Porsche can be pursued by the majority of fans!
在改装了气动避震后,更加凸显时尚炫酷范儿,在正常行驶时可以根据路面状况的不同自由选择爱车的高度,朋友聚会时一趴到底,相信会为你博得更多关注,在遇到烂路时,提高车身高度,增强车身的通过性,采用的是AIRBFT气动空气悬挂系统,是目前生产气动避震最顶尖的研发和生产厂家,质量与稳定性更加值得你信赖!
After refitting the pneumatic shock absorber, it is more fashionable and cool. You can freely choose the height of your car according to the different road conditions during normal driving. When you get together with friends, you will get more attention. When you encounter a bad road, you can improve the height of the car body and enhance the passing ability of the car body. The airbft pneumatic air suspension system is used, which is the current production pneumatic avoidance system Shock the most top R & D and manufacturers, quality and stability more trustworthy!
Taiwan airbft pneumatic shock absorber, specially customized for the actual needs of domestic pneumatic players!
1: Radical cure of individual models (Cruz, Regal, England, etc.)! )With the original model of tower top, equipped with bearing tower top! "Bearing tower top can solve the swing caused by driving direction", so as to solve the problem of air leakage in the later stage.
2: Whether it's an old car or a new model, it's timely and fast to develop a new model! All shock manufacturers can't do the time limit! If you need to customize the long shock absorber for special models! In the same security category, make corresponding measures as soon as possible!
3: In the same model, what is the substantial difference between SF's twisted tooth and pneumatic shock absorbers! Lengthen the length of the shock absorber core, increase the lifting stroke, and deal with the special material treatment and material used when the shock absorber falls to the lowest point! The oil seal also moves frequently! Use top NOK oil seal!
