查看: 751|回复: 0
AIRBFT时尚宝儿向您优雅展示AIRBFT 气动避震的低趴无限魅力
发表于 2020-6-25 16:18:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft fashion show you the charm of airbft aerodynamic shock absorber
A popular saying in the field of refitting is "one hundred changes should be reduced to the first." I'll add that low lying is the king! If there is no pneumatic shock absorber for any refitting, I feel like a walking corpse, with only a bright appearance and no soul! Just as the so-called low cover hundred ugliness, pneumatic shock absorption refitting is the most critical to improve the vehicle's temperament!
New airbft three stage memory version control:
1: Main functions: four wheel independent lifting, front and back independent lifting, overall lowering; adjustable pressure of air tank, working setting of air pump, three-stage memory, remote control of mobile app, automatic raising of ignition, automatic low lying of flameout, support of Chinese and English and other languages, remote control panel with LCD display screen, mainly display 4-wheel air bag pressure value and air cylinder pressure value, more safe desensitization The driving pleasure brought by the dynamic shock absorption culture.
3: Adopt V360 high power ultra quiet air pump to charge faster and quieter.
4: With airbft special leather bag, both the handling performance and comfort performance have achieved the best effect of the same level.
5: Solenoid valve group: the surface of the new valve body is brushed to improve the overall texture of the product.
6: Installation problem: easy to install, easy to understand operation.
The working principle of the pneumatic shock absorber is to change the height of the car by controlling the air pressure, which includes the twisted tooth shock absorber, the air pressure control system and the electronic control system. In auto show or auto friend party, we often see a lot of cars lying on the ground. Many people who haven't seen them will think about how to drive the car. Don't worry, one click to finish you.
