查看: 1030|回复: 0
丰田锐志-姥姥锐成功改装AIRBFT气动避震精彩低姿态案例
发表于 2020-6-25 16:03:51 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Fengtian Ruizhi - grandma Rui successfully refits airbft aerodynamic shock absorber
改装并不是高富帅的专属玩物
改装是一种时尚,一种态度
血液中涌动着机油
如果你也是这样不甘平凡
Refitting is not the exclusive plaything of Gao Fu Shuai
The oil is surging in the blood
If you are not willing to be ordinary
之前每分享一次“姥姥锐”——老车改装分享,总有一到两个留言说是“姥姥锐”......不过从中也看出,老款锐志在车友们的心中和地位。的确是,
对新款锐志,老锐玩起来味道更浓一些,更有情怀,所以现在还有不少的车友在寻找车况好的老锐,进行最后的疯狂。
Every time I shared "grandma said" - old car refitting and sharing, there were always one or two messages saying "grandma sharp"... However, it can also be seen that the old model is determined in the hearts and status of car friends. It is,
For the new model Rui, the old Rui has a stronger taste and more feelings, so now there are many riders looking for the old Rui in good condition for the final crazy.
3:同样的车型,SF的绞牙避震和气动避震有什么实质性的区别!加长避震芯的长度,提高升降行程,避震应对降到最低点的特别材质处理和用料!油封也是频繁
活塞运动!使用顶级NOK油封!
Taiwan airbft pneumatic shock absorber, specially customized for the actual needs of domestic pneumatic players!
1: Radical cure of individual models (Cruz, Regal, England, etc.)! )With the original model of tower top, equipped with bearing tower top! "Bearing tower top can solve the swing caused by driving direction", so as to solve the problem of air leakage in the later stage.
2: Whether it's an old car or a new model, it's timely and fast to develop a new model! All shock manufacturers can't do the time limit! If you need to customize the long shock absorber for special models! In the same security category, make corresponding measures as soon as possible!
3: In the same model, what is the substantial difference between SF's twisted tooth and pneumatic shock absorbers! Lengthen the length of the shock absorber core, increase the lifting stroke, and deal with the special material treatment and material used when the shock absorber falls to the lowest point! The oil seal is also frequentPiston movement! Use top NOK oil seal!
