查看: 766|回复: 0
大众途观向您分享改装AIRBFT加长线气压弹簧充气式减震器的品牌配置效果案例
发表于 2020-6-25 15:37:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen Tiguan shares with you the case of brand configuration effect of modified airbft extended line air spring inflatable shock absorber
说起低趴姿态,将汽车稳稳落地的功臣源于后备箱这小小的气罐。运用物理气压的原理将车身升高降低!来满足改装低趴的乐趣!
低趴改装风格已经成为一种时尚,贴地的车身让它比较倾向超跑,酷酷的外表很是抓人眼球,也许是因为它与众不同!
When it comes to low lying posture, it is the small air tank in the trunk that makes the car land stably. Use the principle of physical air pressure to raise and lower the body! To meet the fun of refitting low lying!
Low lying refitting style has become a fashion. The car body attached to the ground makes it tend to run faster. The cool appearance is very eye-catching, maybe because it is different!
总是发“趴”在地上的车 好多人不理解 疑问也多,就通俗易懂的解释一下
气动,通过改装四支“空气避震+控制器”从而达到在车内随意调节车身高度的目的
很多品牌高端配置车型也会有,它叫做“底盘升降” 差别在哪?升的没我们高,降的没我们低,升降速度没我们快。通常超跑 高端suv顶配才有的配置。
The car that always sends "lying on the ground" many people don't understand and have many questions, just explain it easily
Pneumatically, by refitting four "air shock absorbers + controllers", the height of the car body can be adjusted at will
Many high-end configuration models of brands will also have. What's the difference between "chassis lifting"? It's not as high as us, it's not as low as us, and it's not as fast as us. Usually, it's only available with the top configuration of super run high-end SUV.
空气减震的优势
Advantages of air damping
Air damping uses pure gas as damping medium. It can make the vehicle keep the four-wheel positioning parameters in the proper state as far as possible when it is working, so as to make it more comfortable to ride. When the vehicle passes the uneven road surface, it can effectively resolve the impact, at the same time, it can provide enough side support force when the vehicle is under intense control. Effectively improve handling. Perfect combination of excellent driving performance and good comfort. It can also effectively shorten the braking distance of the car. Save fuel consumption and reduce tire noise.
