查看: 717|回复: 0
GenesisEQ900成功改装AIRBFT高度尺气压悬挂气动气压避震器
发表于 2020-6-25 15:14:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Genesiseq900 successfully refits airbft height gauge pneumatic suspension pneumatic shock absorber
我经常看一些国外的改装案例,很多车辆都会让人深度着迷,不同于国内大批量“同化”的家用车,国外人更希望自己的爱车成为“买菜车”中最稀有的一辆,当然改装文化氛围的不同也有着很多各方面因素的影响,但是我们都是希望自己的座驾在吸引更多路人目光的同时,也能和大家分享改装的魅力!
I often look at some foreign refitting cases. Many vehicles will fascinate people deeply. Unlike domestic large-scale "assimilation" family cars, foreign people prefer their car to be the rarest one among "shopping cars". Of course, the different refitting cultural atmosphere also has many factors, but we all hope our car will attract more people Light at the same time, but also to share with you the charm of refitting!
In recent years, one low cover three ugly is a phrase that is often talked about by car friends, and Hella flush is a kind of modification style that deduces this sentence to the extreme. In hellaflush style refitted cars, in addition to the J value, et value and exaggerated parameter of the hub, the remaining important problem is to reduce the body. So many friends will directly choose the jaw suspension, because the jaw suspension can not only reduce the height of the car body, but also provide sufficient support for the vehicle, which is popular with many car owners. But for Hella flush's ultimate players, the teething shock absorbers have long been unable to meet their "low" needs, so the pneumatic shock absorbers (inflatable shock absorbers) have won the hearts of these ultimate players with their ability to bend and stretch
Taiwan airbft pneumatic shock absorber, specially customized for the actual needs of domestic pneumatic players!
1: Radical cure of individual models (Cruz, Regal, England, etc.)! )With the original model of tower top, equipped with bearing tower top! "Bearing tower top can solve the swing caused by driving direction", so as to solve the problem of air leakage in the later stage.
2: Whether it's an old car or a new model, it's timely and fast to develop a new model! All shock manufacturers can't do the time limit! If you need to customize the long shock absorber for special models! In the same security category, make corresponding measures as soon as possible!
3: In the same model, what is the substantial difference between SF's twisted tooth and pneumatic shock absorbers! Lengthen the length of the shock absorber core, increase the lifting stroke, and deal with the special material treatment and material used when the shock absorber falls to the lowest point! The oil seal also moves frequently! Use top NOK oil seal!
