查看: 837|回复: 0
奥迪R8-背包客改装3/8软管AIRBFT高度尺拉杆32段阻尼软硬可调避震器成功案例
发表于 2020-6-24 17:51:42 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Successful case of Audi R8 backpacker refitting 3 / 8 hose airbft height gauge pull rod 32 section damping soft and hard adjustable shock absorber
它们不仅可以跑,而且跑的可以很精彩!不然怎么能叫“贴地飞行”呢!
The low lying posture that can be seen everywhere in life also causes many laymen to have doubts The car is so low, is it all about running? Do you dare to run in this way!
They can not only run, but also run very exciting! Otherwise, how can we call "flying close to the ground"!
Taiwan airbft pneumatic shock absorber, specially customized for the actual needs of domestic pneumatic players!
1: Radical cure of individual models (Cruz, Regal, England, etc.)! )With the original model of tower top, equipped with bearing tower top! "Bearing tower top can solve the swing caused by driving direction", so as to solve the problem of air leakage in the later stage.
2: Whether it's an old car or a new model, it's timely and fast to develop a new model! All shock manufacturers can't do the time limit! If you need to customize the long shock absorber for special models! In the same security category, make corresponding measures as soon as possible!
3: In the same model, what is the substantial difference between SF's twisted tooth and pneumatic shock absorbers! Lengthen the length of the shock absorber core, increase the lifting stroke, and deal with the special material treatment and material used when the shock absorber falls to the lowest point! The oil seal also moves frequently! Use top NOK oil seal!
