查看: 813|回复: 0
与您分享奥迪A5成功升级AIRBFT电磁阀气压避震低趴魅力HellaFlush风格
发表于 2020-6-24 17:41:54 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Share with you the successful upgrade of Audi A5 airbft solenoid valve air pressure shock absorption and low lying charm hellaflush style
说起低趴姿态,将汽车稳稳落地的功臣源于后备箱这小小的气罐。运用物理气压的原理将车身升高降低!来满足改装低趴的乐趣!
低趴改装风格已经成为一种时尚,贴地的车身让它比较倾向超跑,酷酷的外表很是抓人眼球,也许是因为它与众不同!
When it comes to low lying posture, it is the small air tank in the trunk that makes the car land stably. Use the principle of physical air pressure to raise and lower the body! To meet the fun of refitting low lying!
Low lying refitting style has become a fashion. The car body attached to the ground makes it tend to run faster. The cool appearance is very eye-catching, maybe because it is different!
2. 车身高度一定要尽量低,从车的侧面看绝对不能在轮胎和叶子板之间有空隙。如今HellaFlush已经成为了一个国际化的改装车的外观潮流,越来越流行,越来越被大众所接受,无论类型车种贫富贵贱,HellaFlush已经趋向为一种品味的认证。所以,一起加入这个运动吧!
First, let's break down the word hellaflash = Hella flush, which means there are two parts, one is Hella, the other is flush. Hella is the abbreviation of hellof, which means special, very, absolute and super; flush means flush. So here are two things to understand:
1. The formation of hellaflush should first meet the requirements of flush, i.e. flat hub tire, and then be qualified to work hard from flush to hellaflush;
2. The height of the car body must be as low as possible, and there must be no gap between the tire and the leaf plate from the side of the car. Nowadays, hellaflush has become an international trend in the appearance of refitted cars, becoming more and more popular and accepted by the public. Regardless of the type of car, rich or poor, hellaflush has become a kind of taste certification. So join in the sport!
