查看: 722|回复: 0
强力推荐奥迪A4升级改装AIRBFT三段记忆版本控制气动避震
发表于 2020-6-24 17:22:02 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Strongly recommend upgrading Audi A4 and refitting airbft three stage memory version control pneumatic shock absorber
In recent years, one low cover three ugly is a phrase that car friends often talk about, and Hella flush is a modification style that deduces this sentence to the extreme. In hellaflush style refitted cars, in addition to the J value, et value and exaggerated parameter of the hub, the remaining important problem is to reduce the body. So many friends will directly choose the jaw suspension, because the jaw suspension can not only reduce the height of the car body, but also provide sufficient support for the vehicle, which is popular with many car owners. But for Hella flush's ultimate players, the teething shock absorbers have long been unable to meet their "low" needs, so the pneumatic shock absorbers (inflatable shock absorbers) have won the hearts of these ultimate players with their ability to bend and stretch
The working principle of the pneumatic shock absorber is to change the height of the car by controlling the air pressure. In auto show or auto friend party, we often see a lot of cars lying on the ground. Many people who haven't seen them will think about how to drive the car. Don't worry, one click to finish you.
The installation of pneumatic shock absorbers will link a control remote control in the vehicle, and you can set several gears according to your own requirements, which can realize fast switching between various heights, so that the vehicle can "lie on the ground" when parking, and can rise to the normal driving height when driving normally.
