查看: 727|回复: 0
气动避震论坛李洋分享宝马X1改装AIRBFT新款四轮独立气动避震优点
发表于 2020-7-4 16:31:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
气动避震论坛李洋分享宝马X1改装AIRBFT新款四轮独立气动避震优点Li Yang shares the advantages of BMW X1 modified airbft new four wheel independent pneumatic shock absorber
One low cover three ugliness is a saying often talked about by motorists in recent years, and Hella flush is a modification style which deduces this sentence to the extreme. In hellaflush style refitted cars, in addition to paying great attention to the wheel hub J value, et value and exaggerated camper parameters, the remaining important problem is to reduce the body. So many friends will directly choose the hinge suspension, because it can not only reduce the height of the car body, but also provide sufficient support for the vehicle, which is welcomed by many riders with one stroke. However, for the ultimate players of Hella flush, the toothed shock absorbers have been unable to meet their "low" demand, so pneumatic shock absorbers have won the hearts of these ultimate players by virtue of its flexible ability.
新款AIRBFT四轮独立控制:
安装问题:安装简单方便,操作简单易懂。
New airbft four wheel independent control:
Main functions: four wheel independent lifting, front and rear independent lifting and overall descending; the remote control panel is equipped with LCD screen, which mainly displays the air pressure value of 4 wheels and gas cylinder pressure value, so as to feel the fun of using car brought by pneumatic shock absorber culture more safely.
Solenoid valve group: the new valve group is composed of eight valves, the logo has light display, and the surface of valve body is treated with wire drawing, which improves the overall texture of the product.
Installation problem: the installation is simple and convenient, and the operation is simple and easy to understand.
Product advantages: easy to use with any shock absorber, high versatility, can be combined with any combination, convenient to make a beautiful trunk shape.
Taiwan airbft pneumatic shock absorber is specially customized for the actual needs of domestic pneumatic players!
1: Radical cure individual model (Cruz, Regal, yinglang, etc.)! )With the original car tower top model, equipped with bearing tower top! "Bearing tower top can solve the swing caused by the direction", so as to solve the problem of air leakage in the later stage.
2: Whether it's old cars or new models, the development of new models is timely and fast! All shock absorbers can not do the time effect! If you need to customize the extended shock absorber core for special models! The same security category within the first time to make the corresponding!
3: For the same model, what is the essential difference between SF's hinge suspension and pneumatic shock absorber! Lengthen the length of the shock absorber core and increase the lifting stroke. The shock absorber should deal with the special material treatment and material for the lowest point! The oil seal is also frequent piston movement! Use top NOK oil seal!
