查看: 637|回复: 0
三菱翼神改装 气动避震 引领世界低趴潮流
发表于 2021-6-3 16:24:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mitsubishi wing God modified pneumatic shock absorber leads the world low lying trend
翼神是东南汽车向消费者推出的一款车型,全称为:蓝瑟翼神(Lancer EX)。它交出的一份比较成功的答卷,是把握市场需求、保持产品与时俱进的成功案例。
翼神所追求的"SS理念将速度(Speed)与安全(Safty)有机结合起来并达到了高效平衡。
Yishen is a model launched by southeast automobile to consumers, and its full name is Lancer ex. It handed over a relatively successful answer sheet, which is a successful case of grasping market demand and keeping products up with the times.
The "SS" concept pursued by pterion organically combines speed with safety and achieves an efficient balance.
三菱翼神是一款很具运动气质的紧凑级轿车, 在优秀的车身外观基础上改装AIRBFT气动避震,来玩低姿态,是很多车主都想尝试的一种改装,俗话说“一低遮百丑,百改降为先”,就先来看一下翼神改装AIRBFT气动避震的低姿态吧,给正在想象中的车友一个翼神的低趴案例。
Mitsubishi Yishen is a compact car with athletic temperament. Based on its excellent body appearance, it refits airbft pneumatic shock absorbers to play low profile. Many car owners want to try this kind of modification. As the saying goes, "one low cover one hundred ugliness, one hundred changes first". Let's take a look at the low profile of Yishen refitting airbft pneumatic shock absorbers, Give the imaginary riders a low lying case of winged God.
Airbft pneumatic special barrel is produced by SF shock absorption factory in Taiwan. Shanghai airbft pneumatic shock absorption operation center provides the most accurate model data. The customized pneumatic special barrel is 100% guaranteed to be used for special vehicles. Each model of airbft pneumatic shock absorption has undergone strict testing and adjustment, accurate installation position and perfect comfort, Let players in the pursuit of extreme posture at the same time to create perfect comfort and control for you, so that pneumatic shock absorber is not embroidered pillow, the real practical perfect.
AIRBFT专用气囊:
Airbft airbag:
