查看: 670|回复: 0
AIRBFT气动避震-VX4阀组市场上唯一可以分别调整每个轮子的气流速度
发表于 2021-6-3 13:12:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft pneumatic shock absorber - the only valve on the market that can adjust the air flow speed of each wheel separately
2022款高度记忆,可以相互切换记忆模式,使用更加简单方便,功能如下:新款采用8连阀设计,升降速度比上一款的六连阀更快,苹果手机APP遥控及升级语音控制,可通过语音指令调节车身高度,更加智能化。三段记忆液晶遥控手柄,受到市场玩家的喜爱保持原有外观设计。四轮独立升级,前后独立升降四轮整体升降。气罐压力值可调,空气压缩机开关功能。三段记忆高度功能,着车自动升高,熄火自动低趴。多种语言选项和背光高度调节。全新配套静音打气泵,无焊接旋压一体防爆高压气罐,台湾32段阻尼可调减震器,品质全新升级,更优质的产品和服务为广大车友保驾护航。
2022 height memory, can switch memory mode, use more simple and convenient, the function is as follows: the new model adopts 8-connected valve design, the lifting speed is faster than the previous six connected valve, Apple App remote control and upgrade voice control, can adjust the body height through voice command, more intelligent. Three memory LCD remote control handle, loved by market players, keep the original appearance design. Four independent upgrade, front and rear independent lifting, four overall lifting. The pressure value of the air tank is adjustable, and the air compressor has on-off function. Three section memory height function, the car will automatically rise when the car is on, and the car will automatically lie down when the car is off. Multiple language options and backlight height adjustment. New matching silent pump, no welding spinning integrated explosion-proof high-pressure gas tank, Taiwan 32 section damping adjustable shock absorber, new quality upgrade, better products and services for the majority of riders escort.
