查看: 520|回复: 0
保时捷TAYCAN改装中端AIRBFT气动避震品牌引领世界玩车潮流
发表于 2021-5-23 14:48:21 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Porsche taycan modified airbft pneumatic shock absorber brand leads the world's car playing trend
自从有了自己的爱车,整天想的如何改装以及改哪里的问题。在这其中咨询最多的也就是姿态个性的问题。 我自认为,在日常车改装中如果更换了一套好的避震系统, 即可以尽情发挥。但怎么选择一套适合自己的避震器呢?
Since I have my own car, I always think about how to refit it and where to refit it. Among them, the question of posture and personality is the most consulted. I think that if a good shock absorption system is replaced in the daily modification of the car, I can give full play to it. But how to choose a suitable shock absorber?
