查看: 714|回复: 0
大众途昂原车避震升级气动瞬间改善驾乘舒适
发表于 2021-5-19 15:48:08 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Volkswagen Tuen on original car shock absorption upgrade pneumatic instant improvement of driving comfort
途昂,是上汽大众旗下全新中大型SUV——Teramont,其正式定名为途昂, 在2019上海车展上,上汽大众发布了首款轿跑SUV-途昂X
Tuan is a new medium and large-scale SUV of SAIC Volkswagen - teramont. It is officially named Tuan. At the 2019 Shanghai auto show, SAIC Volkswagen released its first sedan SUV - Tuan X
无改装不兄弟,无改装不快乐。凡是有车一族都想让自己的爱车有种个性超群的一种玩法, 这里笔者就像套用一句话:一千个改装迷手里就有一千个版本的途昂,底盘升降在这几年可谓火爆,主要轿车用来降低车身,完低姿态,一起来看看改装气动避震的途昂改装案例!
No modification, no brother, no modification, no happiness. All the car owners want to make their car have a kind of super personality. Here I like to use a sentence: there are 1000 versions of tu'ang in the hands of a thousand modification fans. Chassis lifting is very popular in recent years. The main car is used to lower the body and keep a low attitude. Let's take a look at the modification cases of tu'ang with pneumatic shock absorbers!
下面就来一步步的分解一下:
Installation of pneumatic shock absorber is roughly divided into four parts, that is, the installation of pneumatic shock absorber, pipeline laying, line positioning, and control system installation!
First of all, the installation of pneumatic shock absorbers. The installation of pneumatic shock absorbers is actually the same as the replacement of ordinary twisted tooth shock absorbers. Shock absorbers are all installed in the original vehicle. What we need to pay attention to is to calculate the maximum and minimum range required by the owner according to the shock absorbers' travel, adjust the height of the throttle shock absorbers, and reserve the position of the air pipes, Generally, the air pipe is on the inside, and the rest is according to the normal shock absorption installation steps.
The laying of pipelines is a time-consuming work. The methods and ideas of every installation master are different. However, one principle to follow is to avoid the places where there may be dead bends or where the air pipe may be pressed or ground by the vehicle while driving, and to stay away from the exhaust, because the material of the air pipe is mostly high temperature, The best way is to follow the oil pipe.
It's very troublesome to move the lines along with the electrical circuits in the car. It's better not to cut off the main power line if you need to disassemble many interior parts. In addition, if there are other electrical equipment in the car, you must not share the power line to prevent mutual interference.
The installation of control system, airbft pneumatic shock absorption control system is quite simple control system, but want to perfect the installation still need to have some experience, there are a lot of details need to pay attention to, especially each joint and gas pipe and gas hole screw tooth connection, should be carefully installed, gas hole and joint screw tooth connection must be sealed, It should be that if there is air leakage, it is very troublesome to check and test again. Try to do it in one step.
