查看: 572|回复: 0
“ 将运动进行到底”G70改装气动避震瞬间成为生命途中美丽的点缀
发表于 2021-5-19 14:27:16 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Carry on the movement to the end" G70 modified pneumatic shock absorber instantly becomes a beautiful ornament on the way of life
捷尼赛思G70,外观上更加运动年轻,市场定位是一款豪华品牌的中型车,海外版有三种动力可供选择,车身尺寸长宽高分别为4685/1850/1400mm,轴距为2835mm。从买来车的那一刻就想改装个性, 咨询如何改装以及改哪里的问题。在这其中咨询最多的也就是针对避震器改装的问题。不过难怪,车辆的避震器可以算的上贫民改装里最最重要也是涉及价格比较高的热点地区,我自认为,在日常的街道车改装中如果更换了一套好的避震系统,以后的改装空间就会缩小很多,即可以尽情发挥。但怎么选择一套适合自己的避震器呢?其中的门道有不少。
The G70 is more sporty and young in appearance. Its market positioning is a luxury brand medium-sized car. The overseas version has three kinds of power to choose from. The length, width and height of the body are 4685 / 1850 / 1400mm respectively, and the wheelbase is 2835mm. From the moment I bought the car, I wanted to modify my personality. I asked how and where to modify it. Among them, the most consulted is the modification of shock absorbers. No wonder, however, that the shock absorbers of vehicles can be regarded as the most important retrofitting for the poor. They also involve hot spots with relatively high prices. I think that if a good shock absorber system is replaced in the daily refitting of street vehicles, the refitting space will be reduced a lot, so that we can give full play to it. But how to choose a suitable shock absorber? There are many of them.
There are three main options for refitting shock absorbers: competitive short spring, suit and twisted teeth. These functions are different, and the prices are quite different. The most important thing is to choose a shock absorber that suits you best. So what is the right shock absorber for you? After replacing and refitting the shock absorber, the first thing you have to bear is the loss of comfort. So if you still pursue the comfort of the vehicle, I suggest you not to replace it. If there is no problem with a little loss, replacing the set can not only improve the handling of the vehicle, but also not lose too much comfort. Because the appearance of the suit is to improve the handling performance of the vehicle on the large structure of the original shock absorber. However, there are also many shortcomings in shock absorber suits. First, the price is slightly expensive. Second, the damping and height can not be adjusted. Third, at present, the main brands of shock absorber suits are still concentrated in European cars, while Japanese car suits are not popular. However, for many senior players, shock absorbers can no longer meet their needs, so tooth twisting shock absorbers have become their first choice. In fact, the word "twisted teeth" comes from Hong Kong, China. Its real full name is height. Adjustable. Damper, which has the meaning of adjustable number of damper segments and body height. Seeing this name, I don't think I need to introduce its functions too much. It's all reflected in the name. However, Xiaobian still needs to add that although the ideal body height and handling performance can be obtained after replacing the hinged tooth shock absorber, it is built on the loss of 60% comfort, so it is best to be prepared before replacing it
