查看: 749|回复: 0
引领低趴潮流AIRBFT气动避震现货秒发
发表于 2021-5-16 14:03:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Leading the trend of low lying down
3: Responsible installation and modification shop, handling every detail, checking before delivery, air leakage, loose abnormal noise, damping height!
4: Before refitting, what you need, how you want to play, whether you want the effect after installation, and whether you have the convenience in the process of use
1: Main functions: four wheel independent lifting, front and back independent lifting, overall lowering; Air tank pressure is adjustable, air pump working setting, three-stage memory, mobile phone app remote control, automatic ignition up, automatic flameout low prone, support Chinese, English and other languages, remote control panel with LCD display, mainly display 4-wheel air bag pressure value and cylinder pressure value, more safe to feel the pneumatic shock culture for your car fun.
The installation of pneumatic shock absorber will link a control remote controller in the car. You can set several gears according to your own requirements. You can quickly switch between a variety of heights. In this way, you can make the car "lie down" on the ground when parking and rise to the normal driving height when driving normally.
