查看: 688|回复: 0
奔驰W140专车专用AIRBFT气动避震气囊
发表于 2021-5-14 11:54:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Airbft air cushion for Mercedes Benz w140
1: Main functions: four wheel independent lifting, front and back independent lifting, overall lowering; Air tank pressure is adjustable, air pump working setting, three-stage memory, mobile phone app remote control, automatic ignition up, automatic flameout low prone, support Chinese, English and other languages, remote control panel with LCD display, mainly display 4-wheel air bag pressure value and cylinder pressure value, more safe to feel the pneumatic shock culture for your car fun.
