查看: 586|回复: 0
超级别的豪华+运动G70改装气动避震诠释“运动优雅”的完美平衡姿态
发表于 2021-5-14 11:27:12 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Super luxury + sports G70 modified pneumatic shock absorbers interpret the perfect balance posture of "sports elegance"
捷尼赛思G70,外观上更加运动年轻,市场定位是一款豪华品牌的中型车,海外版有三种动力可供选择,车身尺寸长宽高分别为4685/1850/1400mm,轴距为2835mm。
The G70 is more sporty and young in appearance. Its market positioning is a luxury brand medium-sized car. The overseas version has three kinds of power to choose from. The length, width and height of the body are 4685 / 1850 / 1400mm respectively, and the wheelbase is 2835mm.
聊汽车改装,或许大家第一时间想到的都是欧洲的汽车品牌。不过在当下,现代汽车的由流体设计风格已经进化到了感性设计,而有了全新的演绎方式,越来越年轻的设计改装,使得很多车性能姿态越来越好看是不争的事实。今天我们要聊的便是韩国的一个豪华品牌——Genesis (捷尼赛思)G70改装气动避震的故事
Talking about car modification, maybe the first thing you think of is European car brands. However, at present, the fluid design style of modern cars has evolved into perceptual design, and there is a new way of deduction. It is an indisputable fact that more and more young design modifications make the performance and posture of many cars more and more beautiful. Today we are going to talk about the story of a luxury brand in South Korea - genesis G70 refitting pneumatic shock absorbers
3: Responsible installation and modification shop, handling every detail, checking before delivery, air leakage, loose abnormal noise, damping height!
4: Before refitting, what you need, how you want to play, whether you want the effect after installation, and whether you have the convenience in the process of use
AIRBFT专车专用皮囊,所采用的天然胶成分比轮胎天然胶成分还要多!单次疲劳次数5百万次到8百万次,正常使用3-5年一点问题没有!都是经过严格的测试设备来进行试压 饱压才能出售 !在皮囊的卡箍环节经过高压力的锁紧设备,皮囊外层都有防腐蚀 防雨水 防沙尘 耐磨材料层层保护!
英文名称:AIRBFT公司地址:江苏省南通市双甸工业园区(淞江集团南通工厂)公司网址:http://hellaflush-china.com 气动避震论坛公司联系:13262966665邮箱:981731567@QQ.com
Company name: Shanghai Songjiang shock absorber Group Co., LtdEnglish Name: airbftAddress: Shuangdian Industrial Park, Nantong City, Jiangsu Province (Nantong factory of Songjiang group)Company website: http://hellaflush-china.com Pneumatic shock absorber ForumCompany contact: 13262966665Email: 981731567@QQ.com
