查看: 572|回复: 0
不留遗憾, 海马323改装气动避震姿态魅力完美提升
发表于 2021-4-28 15:37:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Without regret, the air shock absorption posture of Haima 323 is improved perfectly
海南马自达323轿车采用日本马自达323设计,于1992年正式引进生产。采用的是原装1.6升化油器引擎,在当时来说算是较为先进的一款国产车型。这款海南马自达323虽是10年前的设计,也没有特别突出的单项优势,但在20万以下的国产轿车系列竞争能力仍保持中上水平,它的特点是整体表现十分平均
Hainan Mazda 323 car is designed by Japan Mazda 323, which was officially introduced into production in 1992. It used the original 1.6-liter carburetor engine, which was a more advanced domestic model at that time. Although the Hainan Mazda 323 was designed 10 years ago, it has no outstanding single advantage, but its competitiveness in the domestic car series below 200000 is still at the middle and upper level, and its overall performance is very average
There has always been a saying in the car circle, "a low cover a hundred ugly." Such a famous saying. Even if the car is no longer good-looking, as long as the body is lowered, it can definitely improve the appearance of the car? The super run is low. So as a modification that can improve the appearance and control, how to modify the shock absorber?
Refitting pneumatic shock absorber: pneumatic shock absorber is the most popular refitting project recently. Its simple refitting steps (you can also install it at home) and the feature of no harm to the refitted parts of the car body satisfy the car owners who want to refit but are afraid of hurting their car. Its simple and flexible handling and comfort are still the projects that the car owners are happy with, The above advantages make the pneumatic shock absorber more convenient
Operation: airbft pneumatic shock absorber has four-wheel independent operation (four wheels can control the height, soft and hard separately), three section memory function (can remember the height of three cars, for example: 1 key can be set to the lowest prone state, 2 key can be set to the height of the original car or the most comfortable height for the driver, 3 keys can be set to the highest height. The highest height of the general vehicle is higher than that of the original vehicle) wireless remote control (pneumatic control can be controlled remotely)
