查看: 496|回复: 0
AIRBFT气动避震双泵大罐组装套件
发表于 2021-4-27 13:19:44 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
AIRBFT气动避震双泵大罐组装套件
Airbft pneumatic shock absorber double pump can assembly kit
The installation of pneumatic shock absorber will link a control remote controller in the car. You can set several gears according to your own requirements. You can quickly switch between a variety of heights. In this way, you can make the car "lie down" on the ground when parking and rise to the normal driving height when driving normally.
1: Main functions: four wheel independent lifting, front and back independent lifting, overall lowering; Air tank pressure is adjustable, air pump working setting, three-stage memory, mobile phone app remote control, automatic ignition up, automatic flameout low prone, support Chinese, English and other languages, remote control panel with LCD display, mainly display 4-wheel air bag pressure value and cylinder pressure value, more safe to feel the pneumatic shock culture for your car fun.
