查看: 594|回复: 0
战车 日产“飞鸡”S15改装气动悬挂展示醉美姿态效果
发表于 2021-3-27 14:04:08 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Nissan "flying chicken" S15 modified pneumatic suspension to show zuimei posture effect
S15是Silvia车系中的第七代,也是车型发展史上最低谷的一代,不是说其性能不佳,相反,250匹马力输出,加上优秀的FR布局和已经发展到炉火纯青的前麦弗逊后多连杆悬挂布局。港澳地区习惯性将Silvia系列称之为“飞鸡。”
S15 is the seventh generation of Silvia, and also the lowest generation in the history of vehicle development. It's not that its performance is poor. On the contrary, it has 250 horsepower output, excellent fr layout and the front McPherson rear multi link suspension layout, which has developed into a perfect one. Hong Kong and Macao habitually call Silvia series "flying chicken."
低姿态改装其实日系车是最好的选择,日本的改装文化也是非常厉害,今天给大家分享的这台S15 ,迷彩的车身色彩,演绎低趴效果也是非常不错!
In fact, Japanese cars are the best choice for low-profile refitting. Japan's refitting culture is also very strong. Today, I share with you this S15. Its camouflage body color and low prone effect are also very good!
在气动避震的作用下,把车子降到一个最低的状态、给汽车赋予了灵魂打造了自己的专属!这个就是HellaFlush!HellaFlush不是简简单单一个“范儿”,裡面饱含了太多的执著和艰辛,汗水和等待,一个“范儿”是不能概括的。这是一个不懂的人永远不会达成,懂的人永远不会走错的态度。 最关键的,HellaFlush不分车型,不分高低贵贱
In the role of pneumatic shock absorption, the car down to a minimum state, give the car the soul, create their own exclusive! This is Hella flush! Hella flush is not a simple "fan Er", which is full of too much perseverance and hardship, sweat and waiting. A "fan Er" can not be summarized. This is an attitude that people who do not understand will never achieve and those who understand will never go wrong. The most important thing is that hellaflush has no distinction between models, high and low
Let's break down the word hellaflush = hellaflush, which means there are two parts, one is Hella, the other is flush. Hella is the abbreviation of hell of, which means special, extraordinary, absolute and super; flush means flush. So here are two things to be very clear about:
1. The formation of hellaflush must first satisfy the requirement of flush, that is, flat wheel hub tire, and then be qualified to work hard from flush to hellaflush;
2. The body height must be as low as possible. From the side of the car, there must be no gap between the tire and the leaf plate.
Nowadays, hellaflush has become an international appearance trend of refitted cars, more and more popular, more and more accepted by the public. Regardless of the type of cars, hellaflush has become a kind of taste certification. So, join the sport!
