查看: 576|回复: 0
"尽释豪华之美"英菲尼迪q70升级气动避震演绎HF风格最美姿态
发表于 2021-3-22 14:44:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Show the beauty of luxury" Infiniti Q70 upgrades pneumatic shock absorber to show the most beautiful posture of HF style
英菲尼迪新款Q70L主要变化在于外观设计上,前脸采用最新的家族式进气格栅,相比现款车型设计更有视觉冲击力。此外,新款车型前后灯组结构也进  行了调整,前大灯并加入了LED光源。而在内饰设计上并没有变化,依然保持着豪华品质。The main change of the new model q70l of Infiniti lies in the appearance design. The front face adopts the latest family type air intake grille, which has more visual impact than the current model design. In addition, the structure of the front and rear lamp groups of the new model has also been adjusted, and LED light sources have been added to the front lamps. And the interior design has not changed, still maintain the luxury quality.
Hellaflush has become an international appearance trend of refitted cars. With the development and progress of domestic refitted cars, more and more people accept it. HF model has become a symbol of taste
Let's break down the word hellaflush = hellaflush, which means there are two parts, one is Hella, the other is flush. Hella is the abbreviation of hell of, which means special, extraordinary, absolute and super; flush means flush. So here are two things to be very clear about:
1. The formation of hellaflush must first satisfy the requirement of flush, that is, flat wheel hub tire, and then be qualified to work hard from flush to hellaflush;
2. The body height must be as low as possible. From the side of the car, there must be no gap between the tire and the leaf plate.
Nowadays, hellaflush has become an international appearance trend of refitted cars, more and more popular, more and more accepted by the public. Regardless of the type of cars, hellaflush has become a kind of taste certification. So, join the sport!
