查看: 699|回复: 0
三菱翼神改装AIRBFT气动避震 极致诱惑低趴
发表于 2020-12-20 16:05:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mitsubishi wing God refitted airbft pneumatic shock absorber, ultimate temptation, low lying
三菱翼神在紧凑级车市场主打车型为翼神,定位偏向于运动轿车市场。09年上市,历经11款、12款、13款多个款式的更新换代。
对于紧凑级车更为广泛的家庭用户,翼神显得过于运动化。为了解决这一问题,2013年东南三菱带来了风迪思车型,一款更注重家用轿车市场的紧凑级产品。
Mitsubishi Yishen's main model in the compact car market is Yishen, and its positioning is biased towards the sports car market. It was launched in 2009 and has been updated by 11, 12 and 13 styles.
For the more extensive family users of compact cars, the aegis is too sporty. In order to solve this problem, in 2013, Southeast Mitsubishi has brought in windith, a compact product that pays more attention to the family car market.
在优秀的车身外观基础上改装AIRBFT气动避震,来玩低姿态,是很多车主都想尝试的一种改装,俗话说“一低遮百丑,百改降为先”,就先来看一下翼神改装AIRBFT气动避震的低姿态吧,给正在想象中的车友一个翼神的低趴案例。
Many car owners want to try to refit airbft pneumatic shock absorbers on the basis of excellent body appearance to play a low attitude. As the saying goes, "one low conceals a hundred ugliness, a hundred changes are reduced to the first". Let's first take a look at the low attitude of the modified airbft pneumatic shock absorber by Yishen, and give the imaginative riders a low lying down case.
正所谓一低遮百丑
这几年HF改装火遍大街小巷
气动减震
也是一夜变身改装界网红
Pneumatic shock absorption
话说这是个什么东西呢?它其实是一套可以控制气压改变车身高低的装置,与传说中的主动车身控制系统(ABC)类似,不过它的工作介质是气体,一般来说就是下图所示的这么一套家伙事,其中包括弹性橡胶气囊减震器气压控制系统、后备箱储气罐及电子控制系统等,它其实和空气减震的原理与常见减震器螺旋弹簧+减震筒形式,原理十分类似,只不过,通过改变气室体积(上下方向)来调整车身离地距离并一定程度改变软硬特性,另外减震筒部分则可以由电机改变通气孔尺寸从而调节减震器的衰减力,因此空气减震器往往能提供更好的性能表现嗯!就是这么自信!
So what is this? In fact, it is a device that can control the air pressure to change the height of the car. It is similar to the legendary active body control system (ABC), but its working medium is gas. Generally speaking, it is such a set of things as shown in the figure below, including the air pressure control system of the elastic rubber airbag shock absorber, the air tank of the trunk and the electronic control system, In fact, the principle of air shock absorption is similar to that of common shock absorber coil spring + shock absorber tube. The principle is very similar, except that the distance between the body and the ground can be adjusted by changing the volume of air chamber (up and down direction) and the soft and hard characteristics can be changed to a certain extent. In addition, the size of air vent can be changed by the motor to adjust the damping force of the shock absorber. Therefore, the air shock absorber is often used
Can provide better performance, eh! So confident!
