查看: 652|回复: 0
雪佛兰科鲁兹AIRBFT气动避震施工
发表于 2020-12-16 15:09:22 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
雪佛兰科鲁兹AIRBFT气动避震施工
Pneumatic shock absorber construction of Chevrolet Cruz airbft
雪佛兰科鲁兹(Cruze)是通用汽车以打造设计和性能紧凑型标杆车型为目标,整合全球资源开发的新一代作品。该车或将于明年由上海通用实现国产,以在竞争激烈的紧凑车型中争夺市场。
一直备受关注的全新雪佛兰紧凑车型Cruze(科鲁兹)终于在巴黎车展全球首发,揭开了其神秘的面纱。科鲁兹以其前卫的设计风格吸引了人们的视线,其精密的制造工艺使其有望成为紧凑车型的全新标杆。
The Chevrolet Cruze is a new generation work of general motors, which aims to build compact benchmarking models with design and performance, and integrates global resources. The car may be made in China by Shanghai GM next year to compete for the market in the fierce competition of compact models.
Cruze (Cruze), a new compact Chevrolet model that has been attracting much attention, has finally unveiled its mystery at the Paris auto show. Cruz has attracted people's attention with its avant-garde design style, and its precision manufacturing technology makes it expected to become a new benchmark for compact vehicles.
这几年国内的车友在汽车改装文化的熏陶下,很多车友也纷纷的加入到了这个行列!
汽车改装主要分为两大类,一种是玩性能的,也就是让车子跑的更快或者是有更好的操控;另外一种就是玩姿态,也就是走外观路线的!
下面介绍到的科鲁兹改装气动避震,就是属于后者,在气动避震的作用下将车子的姿态降到最低,是很多喜欢低姿态车友梦寐以求的改装方式!
In recent years, under the influence of car refitting culture, many car friends have joined the ranks!
Car refitting is mainly divided into two categories: one is for performance, that is, to make the car run faster or have better control; the other is to play with posture, that is, to take the appearance route!
The Cruz refitting pneumatic shock absorbers described below belong to the latter. Under the effect of pneumatic shock absorbers, the car's attitude is reduced to the minimum, which is a modification method that many low-profile riders dream of!
Let's talk about the pneumatic shock absorber control system. The mainstream control systems are generally divided into two types: those with memory mode and those without memory mode. Those with memory mode have to mention the control system of airbft in the United States. It should be the first system to enter China. Its stability and convenience of use are trusted and liked by many riders! Let's talk about its function and intelligence!
