查看: 712|回复: 0
李洋分享气动避震改装魅力姿态展示
发表于 2020-12-11 16:32:57 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
李洋分享气动避震改装魅力姿态展示
Li Yang shares the charm of aerodynamic shock absorbers
Let's talk about the pneumatic shock absorber control system. The mainstream control systems are generally divided into two types: those with memory mode and those without memory mode. Those with memory mode have to mention the control system of airbft in the United States. It should be the first system to enter China. Its stability and convenience of use are trusted and liked by many riders! Let's talk about its function and intelligence!
Three segment memory function: the car owner can set three different height modes: high position, normal position and low position by pressing the key 1, 2, 3 When it comes to driving on the road, it can reduce the car's fuel level from 1 to 3 when driving on the road, or it can reduce the car's stability to a certain degree when driving on the road from high speed to low gear, or it can reduce the car's stability to a certain degree when driving on the road from high speed to low gear Gear, to improve the trafficability, from the lowest to the highest about 12 cm journey! Three gears of different heights can be quickly switched at any time!
