查看: 751|回复: 0
马自达昂克赛拉改装气动避震成为网红低趴魅力
发表于 2020-12-7 16:17:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Mazda onksella refitted pneumatic shock absorber to become net red low lying Charm
马自达3昂克赛拉,是由长安马自达汽车生产的一款汽车,采用新一代“创驰蓝天”技术和全新设计主题“魂动”的第三款车型,在2014年北京车展首发。
该车型将搭载两款创驰蓝天汽油发动机,首次导入中国市场的“SKYACTIV-G 1.5L”和具备高效动力的“SKYACTIV-G 2.0L”。
Mazda 3 onksila, a car produced by Changan Mazda, is the third model with a new generation of "chuangchi blue sky" technology and a new design theme of "soul". It was first launched in 2014 Beijing auto show.
This model will be equipped with two types of chuangchi blue sky gasoline engines, which will be introduced into the Chinese market for the first time, namely "skyactiv-g 1.5L" and "skyactiv-g 2.0L" with efficient power.
改装讲究一低遮百丑,百改降为先,所以改装气动悬挂低姿态就成为了当下的一个潮流,国内大大小小的改装聚会以及展会都能看到低趴车辆,今天我们看看昂克赛拉改装AIRBFT气动避震的低趴效果!
Refitting pays attention to one low cover hundred ugliness, 100 changes to reduce the first, so refitting pneumatic suspension low posture has become a current trend, domestic large and small refitting parties and exhibitions can see low lying vehicles, today, let's look at the low lying effect of onxeira refitting airbft pneumatic shock absorber!
气动避震改装的低姿态,也是近几年在国内非常流行的一种改装方式,所谓“百改降为先” 一台车的气质与否,完全取决于车身姿态,降低车身的方法有很多种,为什么大多数玩家会选择气动避震呢?
The low attitude of pneumatic shock absorber refitting is also a very popular modification method in China in recent years. The temperament of the so-called "100 changes to first" depends entirely on the body posture. There are many ways to reduce the body. Why do most players choose pneumatic shock absorption?
汽车避震是由弹簧和减震器共同组成的。
The spring will not be able to control the spring when it bumps up and down.
