查看: 606|回复: 0
丰田普瑞维亚大霸王AirBFT气动改装低姿态达成
发表于 2020-11-21 15:53:39 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Aerodynamic modification of Toyota privia overlord airbft with low attitude
丰田普瑞维亚(Previa)是丰田公司从1990年开始生产的一款MPV,在日本市场称为Estima(エスティマ),而在澳大利亚则称为Tarago,在中国大陆一般称为子弹头、大霸王、超霸王等。
普瑞维亚(PREVIA)的秘诀在于提供充足的空间,同时确保极佳的灵活性,能够按照自己的意愿对车内空间加以调整和利用。
The Previa was established in 1990, and in the first half of the year, it was the first time in the city of MPV, the name of the city in Japan, and in the case of tarago, the great general of the country, the great king, the king of kings, etc.
The fusier (the prevaia) is an empty space in which the satisfaction is fulfilled, and the activity is the same as the activity of the self.
From the first time I saw the car refitted with pneumatic shock absorber to now, I am deeply trapped in it, and I have experienced a lot of twists and turns! Also learned a lot about pneumatic shock absorber refitting knowledge!
气动避震的组成部分分为控制系统和气动避震桶身两大类!
There are three main choices in refitting shock absorbers, which are competitive short spring, suit and twisted teeth. These functions are different and the prices are quite different. The most important thing is to choose the best one for yourself. So what is the right shock absorber for you? After replacing and refitting the shock absorber, the first thing to bear is the loss of comfort. Therefore, if you still pursue the comfort of the vehicle, then I suggest you don't replace it here. If there is no problem with a little loss, the replacement package can not only improve the handling of the vehicle, but also avoid losing too much comfort. Because the appearance of the suit is to improve the handling performance of the vehicle on the large structure of the original shock absorber. However, there are also many deficiencies in shock absorbers. First, the price is a little expensive. Second, damping and height can not be adjusted. Third, at present, the main brands of shock absorbers are still concentrated in European cars. Japanese car suits are not popular. However, for many senior players, the shock suit has not been able to meet their needs, so the first choice for them is to hang teeth. Actually, the word "twisted teeth" comes from Hong Kong, China. Its real full name is height. Adjustable. Damper, which means the number of damping segments of adjustable shock absorbers and body height. Seeing this name, I don't think I need to introduce its functions too much. It's all reflected in the name. However, Xiaobian has to add that although the ideal body height and handling performance can be obtained after the replacement of the hinge suspension, it is based on the loss of 60% of the comfort, so it is best to make psychological preparation before replacement
