查看: 574|回复: 0
精彩绝伦丰田皇冠改装气动避震悬挂低趴魅力高品质享受
发表于 2020-11-7 15:48:04 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Splendid Toyota Crown modified pneumatic shock absorber suspension low lying charm high quality enjoyment
Toyota Crown car group is a large car brand. Toyota Crown was launched in Japan on January 1, 1955. There are more than the 13th generation models. The domestic crown engines are 2.5L, 3.0L and 4.3L. The first two engines are V6 cylinder 24 valve design, and the 4.3L engine is V-type eight cylinder. Dual VVT-i intelligent timing variable system of inlet and outlet valves is configured.
The intake efficiency, fuel economy and power performance of the engine are greatly improved, and the horsepower is more powerful. In terms of chassis, it adopts four-wheel fully independent suspension, which is very comfortable.
皇冠90年代的街车,在那时候是身份、地位、金钱的象征,今天给家分享的是皇冠,经典的外观,大气的设计让老皇冠在现在的保有量依然很大,今天我们欣赏皇冠改装AIRBFT气动避震的魅力姿态,经典永不过时!
The streetcar of the 1990s was a symbol of identity, status and money at that time. What we share with our family today is the crown. The classic appearance and atmospheric design make the old crown still have a large number of people. Today, we appreciate the charm of refitting the crown with airbft, and the classic will never go out of fashion!
喜欢玩改装避震系统的发烧友,空气避震是话题里面最贵的一款。
听起来非常方便,气动避震到底是什么原理呢?
