查看: 533|回复: 0
“有姿态就是任性”福特野马改装气动避震大秀低趴魅力
发表于 2020-11-3 15:31:29 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Posture is willful" Ford Mustang refitted aerodynamic shock absorbers show low lying Charm
Mustang(福特野马)是美国福特汽车公司推出的2005款野马汽车,最高时速232.2公里,设计源自2003 年汽车巡回展上的概念车,野马的诞生标志着美国仅存的大马力轿车获得了重生。
2005款福特野马采用了大胆设计理念,简洁而现代的风格,是美国历史上大马力轿车的骄子。它的设计植根于对历史传统不折不扣的传承,因而才诞生了偶像级的、更具时代感的野马。它毫不客气地把传统的竞争者甩到了身后。
Mustang (Ford Mustang) is a 2005 Mustang car launched by Ford Motor Company of the United States, with the highest speed of 232.2 km / h. The design of Mustang is derived from the concept car on the 2003 automobile tour exhibition. The birth of Mustang marks the rebirth of the only high-power car in the United States.
The 2005 Ford Mustang adopts bold design concept, simple and modern style, which is the pride of high-power cars in American history. Its design is rooted in the complete inheritance of the historical tradition, so it gave birth to the idol level, more contemporary wild horse. It has rudely left traditional competitors behind.
它们不仅可以跑,而且跑的可以很精彩!
不然怎么能叫“贴地飞行”呢!
The low lying posture that can be seen everywhere in life also makes many laymen have doubts With the car so low, is it easy to run? Do you dare to run like this!
They can not only run, but also run very exciting!
气动避震器扣弹性橡胶气囊减震器、气压控制系统、后备厢储气罐、电子控制系统等等。
通过气压来控制改变车子的高低,正所谓一低遮三丑,终极玩家最喜欢的就是可以随心所欲操控车身高度,非常有成就感。
Pneumatic shock absorber with elastic rubber airbag shock absorber, air pressure control system, air storage tank in rear compartment, electronic control system, etc.
Through the air pressure to control the height of the car, is the so-called one low cover three ugly, the ultimate player's favorite is to be able to control the height of the car at will, very successful.
AIRBFT专用气囊:
Airbft special airbag:
