查看: 678|回复: 0
奥迪气动“伪R37如果成不了西装暴徒,那索性就把自己变为绅士
发表于 2020-10-29 15:15:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Audi pneumatic "pseudo r37, if you can't become a suit thug, then simply turn yourself into a gentleman
外形酷似奥迪R8超级跑车的奥迪R3概念车,采用中置发动机,并且将于2008年11月的洛杉矶车展正式亮相。而奥迪R3小型跑车的量产版本,最快将于2013年正式推出。奥迪R3正式投产后,将取代现有的TT跑车。
The Audi R3 concept car, which looks like the Audi R8 super sports car, has a mid engine and will be officially unveiled at the Los Angeles Auto Show in November 2008. The mass production version of Audi R3 small sports car will be officially launched as soon as 2013. Audi R3 will replace the existing TT sports car after it is officially put into production.
同样的瓶子,你为什么要装水?同样的心理,你为什么要充满着烦恼?同样的车,你为什么不改造?改造成自己喜欢的造型,HellaFlush已经是一种潮流,跟随潮流将自己的爱车改造成与众不同及大众所喜欢的造型,今天跟大家分享奥迪R37改装气动避震后的最美低姿态!
Why do you fill the same bottle with water? The same psychology, why are you full of worries? Why don't you remodel the same car? Hella flush is already a trend. Follow the trend and transform your car into a different and popular style. Today, I'd like to share with you the most beautiful and low attitude of Audi r37 after refitting pneumatic shock absorber!
Let's break down the word hellaflush = Hella flush, that is, there are two parts, one is Hella, the other is flush. Hella is the abbreviation of "hell of", which means special, extraordinary, absolute and super; flush means flush. Therefore, two points should be understood here: 1. The formation of hellaflush must first satisfy the requirements of flush, that is, flat wheel tires, and then be qualified to make efforts from flush to hellaflush; 2. The body height must be as low as possible, and there must be no gap between the tire and the leaf plate from the side of the car.
