查看: 836|回复: 0
“游戈天地,闪耀而来”宝马X6气动避震施工中
发表于 2020-10-9 15:59:20 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"You ge Tian Di, shining" BMW X6 pneumatic shock absorber construction
宝马将X6定义为SAC,也就是全能轿跑车(Sport Activity Coupe)。和定位于侧重公路行驶性能的X5相比,X6在公路性能上进化的更为彻底,在外形设计和动力操控上将跑车的运动能力和SUV的多功能相融合。
2019年11月,宝马推出了最新一代的X6系列轿车,新车基于宝马CLAR架构生产,并采用全新的家族脸谱,在配置和动力方面都有提升。
BMW defines X6 as sac, or sport activity coupe. Compared with X5, which focuses on road driving performance, X6 has evolved more thoroughly in road performance, and integrates sports ability of sports car and multi-function of SUV in shape design and power control.
In November 2019, BMW launched the latest generation X6 series sedan. The new car is produced based on BMW's clar architecture and adopts a brand-new family Facebook, which has been improved in terms of configuration and power.
今天介绍的这台改装AIRBFT气动避震的宝马X6,气动避震改装的好处在于能自主的控制车身底盘的高度,能高能低,高速行驶时可以降低车身来降低风阻,越野时可以升高车身来增强通过性,这是原厂所不能比的!下面就是改装气动避震的宝马X6,能高能低,能文能武!
The BMW X6 which is refitted with airbft pneumatic shock absorber is introduced today. The advantage of pneumatic shock absorber modification is that it can control the height of the body chassis independently. It can reduce the vehicle body to reduce the wind resistance when driving at high speed, and can raise the body to enhance the trafficability when off-road. This is incomparable with the original factory! The following is the modified pneumatic shock absorber BMW X6, can be high energy low, can be civil and military!
