查看: 769|回复: 0
起亚GT改装底盘升降气动避震低姿态风格魅力展示
发表于 2020-10-6 16:31:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Kia GT refitted chassis lifting, pneumatic shock absorption, low posture style and charm display
2011年9月韩国起亚第二次发布旗下概念车图片,并命名为GT,此前外界一直称此车为Veredus,此车还将会在之后的法兰克福车展上正式发布。起亚方面还表示,新车将带领他们进入一个全新的篇章。
从命名上也可以看出,这是一款主打性能的操控的跑车概念车型,设计上非常个性,前脸依然采用了虎啸式的前格栅设计,但形状有所变异。GT概念车采用了对开门的设计,车身为溜背式的设计风格,粗壮的腰线设计凸显动感和力量感。
In September 2011, Kia of South Korea released its concept car picture for the second time, named GT. Previously, the car has been called veredus by the outside world. This car will be officially released at the Frankfurt Motor Show. Kia also said that the new car will lead them into a new chapter.
It can also be seen from the naming that this is a sports car concept model with main performance control. The design is very individual. The front face still adopts the Huxiao front grille design, but the shape has some variation. GT concept car adopts the design of opposite door, the body is sliding back design style, the strong waistline design highlights the sense of movement and strength.
