查看: 832|回复: 0
“变形金刚”雪佛兰科迈罗改装AIRBFT气动避震低姿态 完美变身
发表于 2020-8-1 15:59:11 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
"Transformers" Chevrolet komaro refits airbft pneumatic shock absorber low profile perfect transformation
电影《变形金刚》目前共上映了四部。影片中大黄蜂的车型是以雪佛兰旗下Camaro为原形设计的。 第一部中的是雪佛兰camaro(科迈罗) 第二部中的是量产后的雪佛兰科迈罗SS。 第三部中的是雪佛兰科迈罗RS。 第四部中的是雪佛兰科迈罗(Camaro)的全新概念车型。
The movie "Transformers" is currently on four screens. The Bumblebee model in the film is based on the Camaro of Chevrolet. The first one is the Chevrolet Camaro, and the second is the mass production Chevrolet Camaro SS. The third one is Chevrolet Camaro rs. The fourth is the new concept model of the Camaro.
At present, there is no need to say that the two types of pneumatic pneumatic shock absorbers are of high content.
